gm35 converter bush question
i have a powerglide to gm35 converter to ls1 setup and while i had it off to put a spacer in i noticed some very light scoring on the input shaft
after some reading i've found that a bush is required either within the converter or alternatively within the pump drive of the powerglide
hoping someone might know if the gm35 stall converter comes with a bush installed internally
thanks chris
thanks chris
