700r4 > 200 4r
Old 07-14-2012, 01:15 PM
396375's Avatar
Default 700r4 > 200 4r
Can anyone tell me if a 700R4 converter will fit a 200 4R?I was told by a number of people it would fit.I just did the swap and the trans is making a bad noice like something hitting the converter or flexplate.The converter went in fine with about 3/8" between the converter and flexplate before I bolted it up.It only ran for about 5 seconds.Do you think I did some damage?
Thanks
Old 07-14-2012, 01:25 PM
Old School Heavy
speedtigger's Avatar
Thanks
I think there is an early and late TH700 converter. They have a different spline count. I would call one of the sponsers and ask them.
Old 07-15-2012, 03:09 AM
PBA
PBA's Avatar
The torque converter will go in fine, but the 27 (apx. .890" diameter) spline input shaft will just move around in the 30 (apx. .990" diameter) spline torque converter. The transmission will fill up with fluid as the pump is working fine, but the vehicle will not move because of the spline differentiation. All 2004R's were 27 spline. The 1982 to mid 1984 700R4's were 27 spline. From mid 1984 on, all were 30 spline.
Old 07-16-2012, 01:13 PM
nicke's Avatar
Good information. I thought they were all the same.
-Nick
Old 07-16-2012, 01:21 PM
396375's Avatar
Great info.Thanks.
Quick Reply: 700r4 > 200 4r
