Will a truck 4l60e and converter bolt up to an LS1?
Old 08-04-2012, 02:47 PM
Dans69LS1velle's Avatar
Question Will a truck 4l60e and converter bolt up to an LS1?
I have a truck '99 4l60e, and an LS1. I know that the truck bell housing is shorter, will it bolt up? What do I need to do to make this work? Thanks
Old 08-04-2012, 02:55 PM
Bo185's Avatar
If the 1999 is from a Gen III motor then it will bolt right up. If its from a SBC 350 or 305 or the 4.3L it will bolt up but need the correct flexplate and spacer.
Old 08-04-2012, 02:57 PM
Ok that is what I figured. I had issues before with this combo, thats why I asked. Now the truck converter is different from the LS1 converter?
Old 08-05-2012, 01:59 AM
Lee12609's Avatar
truck is a type of vehicle, LS1 is a type of engine. be more specific.
Old 08-05-2012, 07:51 PM
formerly twolow02fransen (2014-1-2)
02_Orange_D1SC's Avatar
only difference between the two is the tail shaft since the trucks dont have a TQ arm setup like the F-BODYS other then that there the same
Quick Reply: Will a truck 4l60e and converter bolt up to an LS1?
