trans acting up out of nowhere
Old 08-07-2012, 07:50 AM
GrnGoblin's Avatar
Default trans acting up out of nowhere
On my way to work today and my trans was like in neutral out of nowhere, put it in reverse got nothing, tryed manualing shifting it still nothing. My car only has 110,000. What's some things that sounds like? I can't pull the trans dipstick, Its stuck.
Old 08-07-2012, 10:23 AM
72blownvert's Avatar
Sounds like either the pump or converter went bad.You need to pull the stick to make sure there is enough fluid.
Old 08-07-2012, 12:17 PM
GrnGoblin's Avatar
Yea It pretty much just shitted out on me.
Old 08-07-2012, 12:24 PM
GrnGoblin's Avatar
It'll drive fine the first few miles then starts acting up.
Old 08-07-2012, 12:43 PM
GrnGoblin's Avatar
Just checked the fluid, it was full, didn't smell burnt or anything.
Old 08-07-2012, 04:11 PM
If it drives for awhile then stops moving the filter is probably clogged with debris. If that is the case its time for a rebuild.
Old 08-07-2012, 04:53 PM
GrnGoblin's Avatar
Where can I locate this filter?
Old 08-07-2012, 06:36 PM
FirstYrLS1Z's Avatar
Filter is located at bottom of trans,exposed after trans oil pan is removed. Potentially messy job,easy filter replacement,be cautious of filter seal replacement/or re-use.
Old 08-07-2012, 06:58 PM
GrnGoblin's Avatar
What's the chances of me just changing the filter and it being okay, IF that's the case? I honestly have no clue. I thought It was weird that it just decided to go out today instead of gradually going out.
Old 08-07-2012, 07:09 PM
If the filter is clogged it's because something is coming apart.If it is the filter it will start slipping before it stops moving. If you let it cool it starts moving again.Are those your symptoms?
Old 08-07-2012, 07:29 PM
GrnGoblin's Avatar
Yes, when the trans is cool it shifts perfect and firm, after about 3-4 miles it sounds like It's going into 3rd then neutral. This just started today and showed no symptoms before. I drove it on the freeway for more then a hour last week without any weird symptoms.
Old 08-09-2012, 07:40 PM
GrnGoblin's Avatar
Messing around with the camaro today. After warmed up, won't do anything except barely move in drive with overdrive off. it rolls backwards In drive with overdrive on, and in 1st 2nd. Sounds like a rattling or scratching noise when in neutral and park. Hopefully that can narrow it down for you guys.
Old 08-10-2012, 08:03 PM
GrnGoblin's Avatar
Filter was clogged up and found a great mess.
