hydraulic fluid in 4L60E?
Old 08-14-2012, 05:54 PM
Jackson98Z28's Avatar
Default hydraulic fluid in 4L60E?
Can I run it in my transmission?
Old 08-14-2012, 06:08 PM
soundengineer's Avatar
NO
use standard ATF Dexron/Mercron III
Old 08-14-2012, 06:10 PM
ArkBird96's Avatar
Why would you want to?
Old 08-14-2012, 06:12 PM
JUSTINSWS6's Avatar
How hard did you fall on your head?
Old 08-14-2012, 06:18 PM
I didn't fall on my head for one. It was a simple question the first person that replied said "no" simple enough....I've heard some people run it in their cars/trucks...mostly race cars though
Old 08-14-2012, 06:20 PM
msydow's Avatar
i know a bunch of guys that run it in their th400's in mud trucks. i work for caterpillar and our 10w hyd oil has a TO-4 additive that makes it acceptable for transmission use in heavy equipment. anyway...i dont know...ha ha.
Old 08-14-2012, 06:21 PM
JUSTINSWS6's Avatar
Have you seen anyone at the strip do this?
Old 08-14-2012, 06:30 PM
I know a couple of people that use it, yes, but not in overdrive
Old 08-14-2012, 06:32 PM
ArkBird96's Avatar
Sorry, but
Old 08-14-2012, 06:37 PM
JUSTINSWS6's Avatar
No reason not to run atf hydrolic fluid is not for auto trannys.
Old 08-14-2012, 06:49 PM
Ok question was answered....thank you soundengineer and msydow for the serious answers. This can be deleted
Old 08-14-2012, 06:59 PM
JUSTINSWS6's Avatar
Go to the top right click "Thread tools" then click delete
Old 08-14-2012, 08:43 PM
gto48's Avatar
I just did a build on a 4l65e in my GTO that I'm running John Deere Hygard in, to tighten up a converter.
I'm having a problem with 3-4 currently, but I don't think it's fluid related.
I'll let you know how it goes...
Old 08-15-2012, 05:21 AM
PBA
PBA's Avatar
I have used and worked with others that have used hydraulic fluid successfully over the last 20+ years. Depending on the type of transmission being used we would mix different ratios of Hydraulic fluid with Dexron III. With Powerglides we would run it straight, same with most TH350/TH400's. With 700R4's most of the time it was a mix of the two, and even more so with the 4L60E's. Using the hydraulic fluid in the Powerglides gave quicker times & faster mph, and in most cases a longer transmission life. When road racing a 700R4/4L60E, the planetaries get very hot and using the hydraulic fluid worked very well at keeping the planetaries alive. For the last few years I have went with Lubrication Engineers Monolec 7500 in 700R4's & 4L60E's to get similar results, and it is easier to get & use this oil straight than using the hydraulic fluid and mixing it with Dexron type of fluid. When torque & horsepower get high, and or extreme use on the transmission, the fluid requirements change somewhat.
Old 08-15-2012, 08:06 AM
WRT
WRT's Avatar
This ^^^^
No reason you can't run Hydro fluid in any auto. That is really all ATF is Hydro fluid with all types having a different additive package. I would recommend John Deer Hygard Low Viscosity 60% ATF 40% Hydro fluid. If you want a tighter converter go 50/50 or 40/60 respectively.
Old 08-15-2012, 09:20 AM
c0ncEpT's Avatar
Yup tons of guys run John Deere Hygard. Its thicker than ATF so it will tighten up your converter a bit. You can also use John Deere Hygard Lite which is a bit thinner and will slightly loosen your converter.
Old 09-18-2012, 08:35 PM
chevelle598bb's Avatar
I use John Deere hygard in every auto I build. I use parts from Dana (PBA). I've used it in glides, 350s, 400s and 4l60es. The last 4l60e I built I ran straight hygard except for one quart of type f for color. Hygard is almost clear and hard to see on the dipstick. With using hygard I have seen better shifting, lower temps and longer trans life between refreshing. It helps the lock up clutch last longer too. I'm not a fan of dexron except in manuals.
Lol.
Old 09-18-2012, 09:40 PM
tittan1500's Avatar
I just switched to John Deere Hygfard and it deffinatly tightened up the converter, but like the GTO above I noticed 3-4 slipping. Could be chance but it happened after the fluid swap
Old 09-19-2012, 02:49 PM
Jake's Performance's Avatar
Using a hydraulic fluid such as Hygaurd, Cat TO-2, TO-4, Mobil 424, etc is fine.
The fluid is designed for use in HD applications with high exposure to contaminants, water, etc.
There are two different viscosities of Hygaurd, I prefer to use the thinner viscosity so it doesn't alter the stall characteristics too much or cause any cold operation issues.
ATF is simply hydraulic oil with a specific additive package and red dye to meet NHTSA/DOT specs.
The hydraulic fluids don't have to meet the DOT specs for red dye so they don't add it. This can make it difficult to read on the dipstick, especially when using a POS Lokar style.
When you check the cross-compatibility, usually the tractor manufacturers specify Dexron as a compatable fluid for top-off.
I prefer the hydraulic fluid in circle-track applications and in any drag racing application where the car may build a lot of heat in the converter (transbraked turbo combos are a good example, especially with a slow spooling setup).
We've experienced some combos where ATF wouldn't live and hydraulic fluid would. One setup didn't even use a converter and never got the fluid hot, but the fluid would smell burnt every weekend. The hydraulic fluid would last a full season.
Old 09-22-2012, 12:52 AM
sjsingle1's Avatar
so where to get this fluid?
Quick Reply: hydraulic fluid in 4L60E?
