feels like i have to hold car back from going!
car idles fine but it feels like i'm holding it back while in gear.. if i let off the brake the car will go about 10-15mph on it's own while idling. problem even exists in reverse but, never raises rpm.. is this normal or is torque converter gonig bad?
the car is a 2000 WS6 with 4L60E
my stock with stock converter idling around 800rpm would do that, not a problem with the current 3200 converter.
its not that its going bad its just very tight. this problem is ALOT worse if you have any vacuum leaks or anything else that would cause a higher idle.
