Locked Converter on Dyno
Old 04-05-2004, 06:48 PM
Ed Blown Vert's Avatar
Default Locked Converter on Dyno
Is it bad for the converter? I want to do a few runs to see how much HP I am losing.
Old 04-05-2004, 10:49 PM
flyin red TA's Avatar
I picked up 30hp doing that. I hear it wears out the convertor faster, but I'm not sure by how much. I've been locking it up in 3rd at the track for years with no problems.
Old 04-06-2004, 08:56 AM
gator's 99TA's Avatar
it is only bad if you run a cheap paper type convertor (like a stock unit or one that is similarly built like stock). the only ones to hurt a unit on the dyno was a Midwest convertor, that wasnt built with strong clutches. your VIg 2800 will be fine.
Old 04-06-2004, 12:19 PM
Ragtop 99's Avatar
no problem for a couple pulls on the dyno.
Old 04-06-2004, 01:05 PM
Great, thanks for the response.
Old 04-06-2004, 01:11 PM
STF Veteran
99-LS1-SS's Avatar
Ed are your times with N2O or N/A? I have almost exactly the same set up as you and I haven't got a chance to go to the track yet.
Old 04-06-2004, 08:05 PM
Those times are with a 100 shot on Nittos spinning. With my ET Streets, I think I can hit low 11's
Old 04-07-2004, 10:54 AM
Mooobunnny's Avatar
My cheap Midwest get locked on the dyno and at the topend of the track.
Chris
Old 04-07-2004, 11:13 AM
I did forget to say, I wanted to spray also when locked.
Old 04-07-2004, 11:14 AM
Chris
Sounds like that would kill the TC @ the track.
What does your rpm's drop to?
Old 04-07-2004, 12:07 PM
locking the convertor on a nitrous run is pretty darn aggressive. make sure you have strong kevlar clutches in that unit!
Old 04-07-2004, 01:11 PM
samz28's Avatar
how exactly do you lock the verter in 3rd gear? And then have it unlock in OD as to not say blow the 3-4 on highway aggressive driving. any url's for setting this up?
i assume at a rpm point you lockup but you definitely dont want to shift to 4th locked up right?
Old 04-07-2004, 02:18 PM
Colonel's Avatar
I don't think that it's going to matter much whether the converter is locked or not when hitting the 3-4 shift at WOT.
WOT 3-4 shifts are clutch pack killers regardless, IMO.
Old 04-07-2004, 04:27 PM
DeepBlueZ's Avatar
the dyno tech uses a scan tool to override the computer and lock the converter....OR you can install youro own switch...
Old 04-07-2004, 05:33 PM
That is what I am worried about, but I want to know what my HP is without the slippage of the TC.
Old 04-07-2004, 08:43 PM
cyipher's Avatar
who has a how to on installing a switch? or a least wiring diagram? And does it throw a ses light
Old 04-08-2004, 04:34 PM
DeepBlueZ's Avatar
i dont have one myself but from talking to people, im pretty sure it WILL throw an SES if you dont tune the code out.
Old 04-08-2004, 07:55 PM
It does throw an SES, and the car won't lock on its own for a while.
Old 04-15-2004, 09:24 PM
I plan on locking it in 3rd before going WOT
