Hitting Rev Limiter 2-3 Shift, Same Tune
Moderator
This is similar to another thread this week. See my reply in #10:
https://ls1tech.com/forums/automatic...fting-wot.html
As 72blownvert says, your 3/4 clutch is probably starting to slip. Slight change that a sensor is starting to produce unreliable data.
As I said in the other thread, installing a shift kit or at least a .500 boost valve to increase line pressure might extend the life of the trans by "a bit". (1000 miles, 10,000 miles, I don't know.)
