Tranny cooler question.
Old 08-23-2012, 08:12 AM
Sail Hatan's Avatar
Default Tranny cooler question.
Im going to be getting an aftermarket stall converter for my next mod, and i want to do the cooler before. now i was looking at the B&M one everyone uses, and planned on running it with the stock cooler also. a friend of mine gave my a small cooler, maybe 8" by 10", with its own fan, and AN fittings a new lines. it was off a race car, i dont know much about it, but it seems smaller than the b&m unit. I like it becasue it has four ports, so i can screw in the sending unit for my newly aquired trans temp gauge, and i dont think you can do that on the B&M cooler that everyone runs? Is it not going to be beneficial running this small cooler? Should I just opt for the B&M supercooler kit? figured id see if this one is any good before i buy the B&M one. ill post a pic shortly.
Old 08-23-2012, 08:29 AM
Sail Hatan's Avatar
Here's a pic, it's actually pretty small.
Is the not sufficient?
Old 08-23-2012, 08:56 AM
mjs1012's Avatar
with that fan hooked up youll be good.
Old 08-23-2012, 11:52 AM
Sail Hatan's Avatar
Also if I was to use the b&m 70264, how would I hook up the sender for the trans temp gauge.
Old 08-23-2012, 12:28 PM
LS-ONE_DAY's Avatar
Get an Aeroforce Interceptor and you don't need an external sensor
The price on it may seem high but it's like 50 gauges in 1. Maryland Speed is a sponsor, check it out on their website.
Old 08-23-2012, 12:53 PM
Sail Hatan's Avatar
Well I already have a gauge that i spent a good amount on, plus I have a scan gauge. So I'm guessing it I just buy a t type splitter I
Can install the sender in that.
Old 08-23-2012, 04:00 PM
mjs1012's Avatar
Mount your temp sender into the transmission pan. Get a bung welded in and just use that. That reading will be pretty accurate. You don't want to put the temp sender in the fluid lines.
Old 08-23-2012, 04:08 PM
Sail Hatan's Avatar
ok. so you guys think that cooler is sufficient? Im planning on a 3800 stall in the next couple weeks so i want to have the cooler and the deep pan done before hand.
Old 08-23-2012, 04:10 PM
Sail Hatan's Avatar
Also what sized barbed fittings will I need, and How much rubber line if I plan on running it in front of the radiator?
Old 08-23-2012, 05:36 PM
LS-ONE_DAY's Avatar
The 70264 will probably be ok. For reference, I drove my car for a while today and kept an eye on my Interceptor for temps with my 3500 and Hayden 30k cooler.
Driving to work, cool outside, maybe like 60-65* out, it got up to 147* unlocked uphill
Driving home, 85* outside, it started at 91* and climbed up obviously, by the time I was cruising locked on the highway it stayed constant at 150*, unlocked going uphill behind slow people it reached 167*, it went down from there to 161* before I stopped at a light and it climbed to 168*, it went back down to 167* once I started moving and stayed there for the next 4 miles til I got home and it showed 168* when I turned off the car.
Old 08-25-2012, 08:38 AM
Sail Hatan's Avatar
awesome thank you. I ordered a B&M 70264 cooler, and will be getting the converter soon.
