4L80e Stalls Car When Put in Drive??
I've had my 4L80 in my GTO now for 3 years and it's performed flawlessly. When I was coming home one night about a month ago, as I was about a 1/4 mile from home in 4th gear it started acting like the lockup was locking and unlocking at weird times. I was able to get it home but it was definitely weird. I looked at it the next day, and when I reversed out of the garage all was normal, but as soon as I put it into Drive it stalled the engine. I verified this a couple times. So I hooked up the logger to my computer and logged what the transmission was doing and it was acting very erratic. It was indicating gear changes while idling, losing TPS and RPM signal randomly, etc. I sent the manufacturer the log and they had me send in the unit. They checked it out and said it worked fine for about 5 minutes then it wouldn't do anything, so they gave me a new one. Thumbs up to them.
Anyways, it's a month later and I get the computer back. Put it in, flash my tune, and the damned car does the same thing
I'm thinking I may have an electrical gremlin, but does anyone have any ideas before I tear into this? I can't confirm that it's the converter lockup that's causing the stall, it could just be trying to go into a gear other than first for all I know, but that's what it seems like.
Ideas? I work 40 hours a week and go to school half time for ME, so I don't have a whole lot of time to be chasing this
Thanks as always!
Adam
***UPDATE*** See post 19 below.
Thanks as always!
Adam
Moderator
About the only thing that can stall an automatic is the converter going into lockup; doing into something other than 1st gear won't do that.
Sure sounds like an electrical gremlin; I would start by running a 12-gauge ground wire from the trans to the chassis to be absolutely sure the trans is well grounded.
BTW - I had the lockup clutch in a converter partially bind up; the engine was then likely to stall in both reverse and in drive.
Hopefully someone else has more ideas.
I'm not 100% sure but I think the "other" speed sensor is responsible for converter lockup.
Also are you sure your file that you flashed isn't corrupt? Idk how long it has been since you last flashed the computer before it started acting up but if it was recent it could be a problem.
Moderator
Good suggestion. I actually removed it to be absolutely sure there was no TCC apply fluid. (In case the lockup solenoid was stuck.)
Moderator
Without the computer plugged in the trans goes into "Limp mode" which is 2nd gear on a 4L80E. Only the computer can make the trans shift.
So if I was in second gear with the computer unplugged, it should have had fluid at the TCC solenoid, which should have allowed it to locked. Hmm so maybe it is more electrical.
I'm going to find the TCC wire in the harness and cut it tonight. Then see what happens
with the computer plugged in.
Thanks for the help guys, and keep it coming!
The car doesn't have a PRNDL switch. When I swapped the valve bodies I effectively changed all solenoids and that little pressure switch manifold thing. What's this inhibitor?
The only thing electrically connected to the car is the TPS, RPM signal, big grey connector on the side of the trans, and the speed sensors on the trans.
"what the transmission was doing and it was acting very erratic. It was indicating gear changes while idling, losing TPS and RPM signal randomly, etc"
Check to see if this issue was fixed? It looks like it's a problem that affects all aspects of transmission function. I would look for grd and power issues.
UPDATE
So we cut the wire in the trans harness for the converter lockup. Car now goes through all of the gears and seems to be working perfect, with no lock up of course. I drove it around for about 10 minutes tonight with no issues.
Anyways, I'm not sure what that leaves as the culprit but I will investigate more tomorrow. A few questions.
Is the lock up solenoid just fired by 12v? If so I will wire in a switch so I can manually apply the lock up and then I can see if it releases when I flip the switch back.
Also, what is the difference in a 4L80e valve body with a PCS accumulator and without? I have one of each and was just curious.
All ears for any other opinions as well
Gingervitis Addict
UPDATE
The lockup solenoid controls a valve in the valvebody. No fluid gets to this valve until 2nd gear gets oil.
Your lockup wire grounds to activate lockup.
