Littel help trans cooler
I really need a trans cooler the transmission has been fully built small stall heats up in traffic I'm a newbie and would like to put a cooler with a fan but don't know what one and what fittings and lines I need please help need to get her back out on the road there is car show coming soon thanks for the help in advance
Best place is in front of the AC condenser if you have AC or dope style if you have ram air I believe are the two usual solutions to mounting. Dope style is mounting flush under the passenger side on the front clip. A 70264 will fit there. Dope will usually run a little warmer than the same cooler facing the front of the car because of moving airs cooling effects unless it has an external fan.
Mine never blew off, and the 264 kit is all screw on fittings, nothing clamped except at the cooler itself. I eventually swapped to this:
https://ls1tech.com/forums/automatic...oler-line.html
