Good hoses to use for tranny cooler lines.....??
Moderator
Running high pressure hot oil through long sections of rubber hose near headers would make me very nervous. How high is the pressure? Is it line pressure at nearly 200 psi?
One touch to the headers and you will be needed a new transmission.
Using Teflon AN hose and connectors makes the lines flexible and easy to remove/install.
Since my trans cooler has fittings for AN connectors, I don't have rubber anywhere.
Just my opinion.
Just my opinion.
Just my opinion.
Just my opinion.
The lines won't even get near the radiator.
How can I make these teflon lines attach to the cooler I have, which just uses worm clamps?
I'll have to measure the lengths I need. Whats the price for (Steel Braided) two 4' lengths and four fittings to weld to my two cooler ports and to the ends of my factory tranny cooler lines ?
The two lines need to run from where the factory tranny cooler lines end out in front of the engine.....to the cooler you see in my pictures in my above post. I think two 4 foot lines will be fine.
I have a basic B&M cooler......
How about this if 3 feet will work.....?
But what fittings go on the ends????
http://www.jegs.com/i/JEGS-Performan...oductId=761335
its an AN hose, so just get matching AN hose ends...you just need to know what fittings are on your transmission and on your trans cooler...
the coolers have a 6an, and teh typical fittings for the trans is usually 6an as well..
its also a lot easier to get the AN hose ends onto it than using braided steel lines...
I used that stuff for my fuel lines on my camaro
You will need to use the AN fittings with that hose from Jegs. You can not use the barbed fittings and a clamp with that, it isn't flexible enough to pull over the barb.
Using short links where you are the cheap way would be to get rubber hose for transmission oil cooling, I bought some the other day at Advanced, 5/16" for $1.99 a foot, they had a big spool they cut a few feet off for me. It specifically says for "transmission oil cooler" on the hose I bought. I was using this on a car I was doing for someone else, because most people won't pay the price of braided stainless lines, and the correct AN fittings. Doing it the way I did with barbed hose fittings it was about $25, it would have been $100+ using stainless braid -6 hose and fittings.
If you go stainless ot that other hose from Jegs, you should probably run right from the transmission to the cooler in one piece, and get rid of the factory lines. You need 1/4" pipe thread to -6 male adapters on the tranny(you'll need 2), put fermale -6 ends on each of the hoses(you'll need 4), and then you need adapters to fit your tranny cooler's input(you'll need 2 of these). This is definatly the harder more costly route to go, but it probably the way I would do it if I did it on my car.
Moderator
ScottBG's comments are good.
However, the "1/4" pipe thread " is not quite right. A pipe thread (which is tapered) will often work, but can also crack the case. Technically it is a straight thread with o-rings. AN6 adapters are available. Also it appears the oil cooler threads changed somewhere around 2008. My 2010 trans is neither 1/4" pipe nor straight; but an AN-6 male to make with an o-ring fits perfectly.
