1st to 2nd shifting issues th350
Quick info on the car and trans.
I have a 86 rx7 with a 5.3l and a th350 trans. The trans has a trans go shift kit and 3000 stall.
The issue i am having is that under WOT the trans will not shift from 1st to 2nd but shifts from 2nd to 3rd flawlessly. It does not matter if i shift it manually or leave it in the drive position it still will not shift the car. It will take it all the way to the limiter and even then it will not shift the car untill you let out of the throttle.
I think i have it narrowed down to the weights in the governor since its only at WOT, but wouldnt that change the shift point of the 2nd to 3rd shift also? I was curious as to what everyone thinks i should check or look into.
Also, not sure if this is related, but vary rarely it will not downshift to 1st when coming to or leaving a stop. this issue rarely happens but did not know if it was related or not so i figured i would throw in a little more info
Thanks for the help guys.
