Did I screw the pooch?? HELP!!!
I got my 5.3 and 4l60 in my truck just about ready to fire up and decided to bump the starter and hear it turn over.....but all i got was a clunk!! I attempted to roll it over with the crank hub and it wont turn at all. After poking around on here, I see the posts about convertor spacing and i'm not too sure about wether i got it right. When I put the two together, I didnt force anything, but I'm pretty sure I didn't spin it and get any clicks...ugh
I didnt use the bolts to pull the trans and engine together so I'm hoping I didnt ruin anything, but with my luck, I probably did....I'm pulling it all out tomorrow but am wondering what I should check on the trans to see if I screwed it up?? If I did, what will it cost to fix it???
Moderator
If the crank won't turn, I would guess that one of the converter bolts is not in all the way and has hit the back of the block. You may have to loosen all the bolts between the trans and engine to create enough clearance to turn the crank and check the converter bolts.
Just a guess; cOncEpT is right that even if you broke the pump the engine will start.
Rented an engine hoist at 9 am. took it to the storage building I have the truck in. Pulled the front sheetmetal, core support, rad, etc.Tore it down to a long block. Took it all out, nothing looked broken or damaged, reseated the converter, went to spin the motor before I put em together and it would move a little, but not a full turn....pulled the plugs, sprayed pb into the cylinders and noticed something muddy coming outta the back cylinder....muddobber nest!! shop vac'ed it out, re sprayed the cylinder, and she spun around nicely! put it all back together and back in to the truck...spun it over with the starter no problem! Closed the door at 5 pm. I'll finish putting the rest together over the weekend and hope to fire it up soon!
mud dobber in the cylinder with plugs in it??? sneaky little bastards. they wouldve had to go through the exhaust or intake valve if they heads were on. never heard of that. how long has it been sitting?
