what convertor for DD??
so Im putting my 94 bird together and right now I have the trans apart from the motor and I think it would be the best time to swap out my convertor and maybe have a shift kit installed into my trans, I just picked up a posi unit and 373 gears for my car and I do a lot of highway driving to the city for work, the car will see some track time but not alot, Right now the motor is a 94 Lt1 4l60e stock with shorty headers, I do plan to do some performance upgrades down the road even a procharge if funds allow. So i figure I see what you guys all think I should go with. Thanks.
I run a modified Trango kit from Probuilt automatics and the Yank SS 3600 converter. After 7 1/2 years of flawless use, I wouldn't recommend anything else.
Contact PTC. best prices. best converters. the best customer service. trans go has the best shift kit. hd-2. ebay has best prices at around 90-100 dollars that ive found. good luck with the build. i have a trans with a hd2 shift kit with only 44k miles on it sitting in my house waiting for a new home.
A converter is a massive differance. Maybe he was saying your daily drive will be near stock. I just installed an FTI 3200 stall in my Tahoe and it is barly looser then the stock converter. But you get on it and you a squeeling tires and shitting and getting unlike when it had the stock stall.
LS1Tech Sponsor
Krzy, Give me a call at the shop and I will spec you out a converter, I would install a transgo HD2 kit while you are at it and I have them in stock as well.
1-386-736-5816
Greg
1-386-736-5816
Greg
__________________
FTI COMPETITION CONVERTERS AND TRANSMISSIONS
"IT'S NOT CHEATING, IT'S THE COMPETITIVE EDGE."
1-866-726-8358
info@ftiperformance.com
FTIPerformance.com
FTI Converter build sheet
1-866-726-8358
FTIPerformance.com
LS1Tech Sponsor
What is meant is that a converter will reduce your et by at least 3-4 tenths and yet still drive great under light pedal.'
Greg
Greg
__________________
1-866-726-8358
FTIPerformance.com
1-866-726-8358
FTIPerformance.com
