M6 To A4 trouble
Old 10-06-2012, 08:25 AM
suspectz28's Avatar
Default M6 To A4 trouble
I have a 99 m6 that I have taken an a4 from an 98 , the trans is in and the wiring harness from the 98 is in. The car will not start now. Has no fire and no fue.. Any idea what has gone wrong?
Old 10-07-2012, 12:01 AM
Pontiacerator
RevGTO's Avatar
The 99 PCM is incompatible with the 98. I have no idea how you wired the 98 harness to the 99 PCM, but they will not work together.
Old 10-07-2012, 11:25 AM
suspectz28's Avatar
I didnt have to wire anything in. I just pulled the harness from both cars and put the 98 auto harness in the 99 m6 car. put the 4l60e tranny in. I then tied i the cluch wires in to the safty switch on the stock shifter and now have no firing or fuel pump... I have no idea what is going on being that it was running before I started this swapp..or and I also have tried the 98 auto computer in it and have tried the 99 m6 one and nothing changed?
Old 10-13-2012, 07:45 PM
1BADAIR's Avatar
auto and manual body harness are not the same. check pin locations of the two connectors in the right kick panel. the 98 harness also requires 98 pcm.
98 also have cluster controlled alternators instead of pcm
Old 10-22-2012, 05:58 PM
zerofx150's Avatar
the 98 ecm is different than the 99 and newerr from what im told. i jumpered my blue clutch connector to get mine to start.
Quick Reply: M6 To A4 trouble
