4L80e pump bolt torque specs?
Old 10-06-2012, 11:27 AM
Mightymike2000ss's Avatar
Location: Home town Clive,IA current town FORT BENNING GEORGIA
Default 4L80e pump bolt torque specs?
Had a leak coming from the pump on my 80 so pulled the pump and put a new gasket, o-ring, and converter seal in it while it was out. Now i need the proper torque specs. Everywhere i have looked i have found it saying 18 ft/lbs but that seems like it would be really low for such a major component. Please help!
Old 10-06-2012, 12:12 PM
MUSTANGBRKR02's Avatar
ATSG manual says 18ft lbs. proper torque is usually a bunch less than what you think it would be.
Old 10-06-2012, 12:49 PM
Yeah just seems really low for one of the big main components lol
Old 10-06-2012, 01:11 PM
I just tore my 80e down to 500 pieces last night. A lot of crap shoved in there.
Old 10-06-2012, 01:34 PM
Lol yeah. that is why i am going to pick up a jake's 80e when i kill this one off. don't feel like trying to have it rebuilt anywhere around here
Old 10-06-2012, 02:16 PM
RedRocketZ28's Avatar
What are the thoughts on the bolt o-rings and washers? We didn't see any on the 80E we were working with. Do they all have this and could this have been the source of the leak?
Old 10-06-2012, 04:48 PM
Mine didn't have any with washers or o-rings on bolts.
Old 10-06-2012, 05:20 PM
Sounds good. Thanks man.
Posted from LS1Tech.com App for Android
Old 10-06-2012, 10:17 PM
BattleSausage's Avatar
I would double check those bolts. I didn't think mine had any either but after careful examination I found that I was wrong. I was under the impression that is the culprit many times also because people don't replace them or remove them and forget. Just a thought but I'm sure Jake would clarify.
Old 10-07-2012, 11:02 AM
Ill have to go look again.
Old 10-07-2012, 01:50 PM
After closer examination, mine had o-rings on them. Of course they were all crushed down and brittle. Got some new o-rings, hoping they work.
Old 10-07-2012, 02:35 PM
Well after looking again the bolts do have recessed o-rings in the flange of the bolt.
Old 10-07-2012, 05:27 PM
That's what happened to me and I damn near overlooked it. Glad you guys found them as I was advised to always replace them.
Quick Reply: 4L80e pump bolt torque specs?
