Sonnax 77701-076 opinions
Old 10-09-2012, 03:29 PM
white3800camaro's Avatar
Default Sonnax 77701-076 opinions
Anyone use these?
What was the outcome?
Good? Bad?
Thanks
Old 10-12-2012, 06:01 AM
Moderator
Vince B's Avatar
They work and I have used them at times on and off for years. Might I make a suggestion if you are planning on tweaking your trans try the sonnax HP kit for this trans. It comes with a good amount of stuff to address many different things with the valve body, pump and accumulators/One of the items included is the servo release check valve you have listed. I do add a couple things to the kit that included two new abuse valves and also the HD2-3 shift valve from sonnax. HTH Vince
Quick Reply: Sonnax 77701-076 opinions
