4l80e VSS question (picture inside)
I got this 4l80e from Jakes Performance a few months back and I'm just gitting around to installing it. I noticed when I went to plug in the front VSS there was no connector. I can't remember if it was ever there or if I'm imagining it. I looked everywhere thinking that I could have broke it and it fell somewhere in my garage but no luck finging anything. The image below is the only thing there, not sure if its a plug or a piece of the VSS. let me know what you guys think. Need a PN if anyone has it seeing that I dont have one.
Segment swap is are you running a 4L80e truck trans segment in your pcm?
4L60 cars only had one vss connector, that's all I have connected on my swap running the 4L60e segment instead of a 4L80E segment in my pcm.
Hope that helps.
Hope that helps.
