4l80e flexplate for ls1?
Old 10-31-2012, 03:52 PM
gpr
gpr's Avatar
Default 4l80e flexplate for ls1?
I was originally going to run a lq4 motor, but plans have now changed. I have the 4l80e and converter but it will run with an ls1. Can i simply use the flex plate from the lq4 engine on the ls1, then the spacing and bolt patter will be correct for the 4l80e converter?
Old 10-31-2012, 04:21 PM
Circle-D's Avatar
It should work.... Are you running a stock converter?
Chris
Old 10-31-2012, 05:35 PM
gpr
gpr's Avatar
Nope i already have an aftermarket 4l80e converter. I was told it would bolt right up to the lq4, but wasn't sure about the ls1 and how to make it work. I'm glad i can simply reuse the flex plate from the lq4.
Quick Reply: 4l80e flexplate for ls1?
