Pros: How to prep sprag races and beast roller shaft
I am building a 4L60e in a 96 vette.
I heard on forward sprag you should sand the outside of the. Inner race. What is best way to prep this, and what should I look for?
Also, is any prep needed for low roller clutch sprag? I assume you should also sand the outer surface of inner race?
I also already have beast sun shell. I will be doing 5 pinion planet with roller bearing reaction shaft. Eliminating bronze thrust washer will still leave 4 square holes in the sun shell. Is this setup OK or do I need a different shell without the washer holes?
The inner race should be "flat" and have a mirror finish. The outer race should be rough. Sand in the direction of rotation with 36 - 40 grit. The sprag itself should have low miles or replace it. The Beast sunshell is fine with the holes. They do not present any problems. Take a small flat file and file flat the area where the bearing is going to ride on. This will eliminate any high spots. Sand flat the rear inner race where the plastic washer that sits on the Beast sunshell rides on.
Thanks for the reply Dana.
I have some additional questions, just so I get it right.
If I understand right, the inner race refers to the center section that rides inside the sprag and should not need to be touched.
The outer race on the sprag rides on the inner surface of the hub, meaning I sand the inside of the hub?
On the low roller clutch, no need to sand the hardend circular outer race, just need to make sure the flat face that the plastic thrust washer rides on is flat or sanded flat?
Trying to make sure I get this right.
Moderator
