bolting TC to flywheel
bolting TC to flywheel HELP! HELP! HELP!
the bolts that came with the converter will not go in, the bolt on the head is rubbing the frame and it seems like too large of a diameter to thread in anyway. I tried to reuse the stock bolts but once they go in all of the way, they just keep spinning. A buddy and myself are 90% done with this install and would like to get this taken care of. Any suggestions would be greatly appreciated. Thanks in advance!
Is it a TCI converter? For some reason TCI taps their converter mounting lugs with SAE threads. I think 9/16x18. I think they even require that you drill the holes on the flexplate. They really should get with the program and tap them M10x1.5 like everyone else does. Then you could reuse the stock bolts or use the late model GM hex head metric bolts part # 1261968. There would be no need to drill the flexplate then also. Everything else on these cars is metric.
The bolts I gave the part # for are M10x1.5. Same thread as the stock converter bolts except with a hex head instead of the allen head. I'm afraid if you didn't drill the flexplate so the SAE 9/16x18 bolts will go through, you are going to have to. My point was TCI needs to reengineer their converters to use the same metric thread bolts as the stock converter. Yank and PI does.
so either way i am going to have to drill to flex plate? Am i going to have to drop the tranny again to do this? Or is there a bolt that i can use that will just go in? I really appreciate the help
oh I got ya, i just thought that they were all flywheels. So im gonna have to get the flex plate drilled and then the bolts that TCI sent me should work? Or will i have to get the converter holes drilled out too? Sorry for so many questions but the transmission is really the only thing that I have never worked on, and now I know why! Thank you though, you have been extremely helpful.
I just installed my brothers tci 3500 about a month ago and in the instruction it tells you to drill out just one of the holes, the bolts will work on two of them, I only had to drill one of them. it tells you that in the instuctions or atleast on his convertor it did.
Originally Posted by 2000blackta
the one hole that you drilled out, did you do it with the tranny and flex plate still bolted to the car? I just really don't want to drop the tranny again
