4l60,80e question
Old 05-08-2013, 04:25 PM
tonytone4143's Avatar
Default 4l60,80e question
i am piecing my build together. now, my question is i have a 04 ls motor and would like to know if any of the older trans will work or do i have to get a trans out of a ls series van or car? thanks for the info in advance.
Old 05-08-2013, 06:32 PM
Moderator
mrvedit's Avatar
A '98 through '06 4L60E for a 2WD V8 will work best as that is probably what the PCM was designed for. (Assuming this is not a 4WD vehicle.) An older 4L60E will require some adapters and might not be electrically compatible with your PCM.
Otherwise refer to this sticky:
https://ls1tech.com/forums/automatic...questions.html
Old 05-08-2013, 08:12 PM
ok thank you. i wasnt sure if it was possible.. no, its not a 4x4 vehicle. its going to be a hybrid swap.
Quick Reply: 4l60,80e question
