Need help fast!!
Need help fast!!
I was installing my stall converter and I have everything undone from the tranny and it is hung up at the top of the tranny. There is a inch at the bottom between the engine and tranny and the torque converter in un bolted
I dont know WTF is the problem is.
are you sure you got all the bell bolts {6} , lines are unhooked, dip stick tube is clear, did you try lowering the trans because the bell might be hitting the tunnel. All electronics are unhooked.possible it's just stuck on the dowel pins?
am I reading this right? The tranny hasnt come down yet? removing the 3 bolts holding the converter to the flywheel kicked my *** for awhile, i thought there were more than 6 bolts? I think there is 8.
