Vibration after 4l80 install
Old 05-09-2013, 12:40 AM
mobinlow&cln's Avatar
Default Vibration after 4l80 install
I am running the bmr crossmember with the factory torque arm and I had to set it on the highest setting because it wouldn't go any lower without hitting my Trans mount (energy suspension)..it not a huge vibration but can feel it at hwy speeds .. Just seeing if anyone else ran in to this problem.. It's a 99 Camaro
Old 05-10-2013, 10:29 PM
willizm's Avatar
I noticed a similar vibration and just contributed it to the BMR crossmember. Would be interested to hear if others have this as well or if the guys that sell these setups with the bmr like Jakes have experience with this. it's not terrible, but definitely noticeable.
Old 05-11-2013, 08:34 AM
"All Motor 9 Second club member"
TXCAMSS's Avatar
It's the Energy Suspensions poly mount. Vibration is a common complaint when the poly mounts are installed, but it won't break easily like the standard rubber mounts. GL
Old 05-11-2013, 11:29 AM
Blackpanther99's Avatar
Its the transmission mount. Its a pretty normal thing, but you shouldnt run into any problems.
Quick Reply: Vibration after 4l80 install
