Confused on on running trans hoses
4l60e trans
And using a F body radiator with a older b&m cooler
How should I run these lines?
The top port or the bottom port on the trans case is thie in and out
Also does it matter which line goes in or out on the radiator as one port is on top and other is on bottom?
Yes it does matter, ..., Read, read, & read more, ...
https://ls1tech.com/forums/8963689-post3.html
Also see the other 'stickies' up top here.
https://ls1tech.com/forums/automatic...lush-more.html
I know that's not the direct answer you're looking for, ...
Edit, Searched & found this;
https://ls1tech.com/forums/automatic...ns-cooler.html
And this;
http://www.bowlingss.com/LS1_How_To.htm
Read the Transmission links.
And this;
