what bolts for cat racing sfi flexplate
Old 05-30-2013, 07:22 AM
greenvortec97's Avatar
Default what bolts for cat racing sfi flexplate
Can I use stock gm bolts or do I need special ones? I have 4l60e
Old 05-30-2013, 07:45 AM
Moderator
mrvedit's Avatar
Most SFI flexplates are thicker and you need longer bolts.
IIRC the stock bolts are only 12mm and you probably need 18mm.
CircleD sells a wide variety of converter bolts including ones from ARP.
I just use hardware-store 1cm (25mm) long fine-thread bolts with a 9.8 or 10.8 hardness. I add a very thick hardened washer (about 3mm) under the head. If doing this, first make measurements to ensure the bolt doesn't bottom out in the converter before it reaches full torque; allow about 1 fine thread for stretch.
Update - This is for flexplate to converter. Not what you wanted.
Old 05-30-2013, 08:07 AM
Super Hulk Smash
JakeFusion's Avatar
ARP 244-2901 Flexplate Bolts would be my choice.
Old 05-30-2013, 08:22 AM
Sorry guys I have the converter bolts. I need to know which ones to use for the crank
Old 05-30-2013, 08:45 AM
Super Hulk Smash
JakeFusion's Avatar
The ones I listed are for the flexplate to crank.
Converter bolts are ARP 230-7304 Torque Converter Bolts.
Old 05-30-2013, 08:47 AM
sopes's Avatar
ARP! lol
Old 05-30-2013, 10:39 AM
Thanks guys
Old 05-30-2013, 10:34 PM
01ssreda4's Avatar
It is slightly thicker then stock but the stockers are 10.9 grade IIRC and should hold no problem.
Old 05-30-2013, 10:36 PM
too late i bought the ARP lol its all in the car now.. just need to bolt Stall to flexplate and install everything back in its place
Quick Reply: what bolts for cat racing sfi flexplate
