4L60E year question
Old 06-03-2013, 01:38 PM
softail02's Avatar
Default 4L60E year question
Hello,
I have read through many posts and still a little confused... My kid has a 97 RS that has reverse blown.. I did see that 96-97 4L60E trannys are compatible but what about 98-02 would these also drop in without any of modification or parts to buy.
Thank you in advance
Old 06-03-2013, 05:23 PM
Moderator
mrvedit's Avatar
Originally Posted by softail02
Hello,
In short, NO. Your '97 has a 298mm input shaft and converter. There was a big switch in '98 to a 300 input shaft and different depth bell housing. GM actually makes a conversion kit, but it will move your trans back, cost money, etc. (Its a bad kludge.) You really need to stick with 96-97; earlier ones will not be electrically compatible. (Not PWM)
HOWEVER, '98 and later V6-compatible 4L60E are still 298mm and therefore might fit. One of the trans builders will need to answer that for sure.
Old 06-04-2013, 07:17 AM
softail02's Avatar
Default 4l60e
Great Thank you.... So a V6 may fit my car is a v6... how about a 97 tranny in general are the bellhouses and input shaft the same ? I see this tranny as advitise as a 97 but from a T blazer would this bolt straight up or could I just swap out the B-housing ?.. sorry I sound stupid but I am old school Turbo 400 behind my 1100 BBC blown 70 camaro anything made after 1990 I am clueless about ...... Also you said a V6 might work this person seems to think 96-2002 v6 will fit.. any help would be much appreciated
http://www.ebay.com/itm/Rebuilt-1997-Blazer-Jimmy-Bravada-4L60E-transmission-/330834685545?pt=Motors_Car_Truck_Parts_Accessories&hash=item4d0748ae69&vxp=mtr
http://www.ebay.com/itm/Camaro-Firebird-V6-4L60E-Automatic-Transmission-1996-02-3-8L-3800-base-model-rs-/271136599942?pt=Motors_Car_Truck_Parts_Accessories&hash=item3f21002f86&vxp=mtr
Quick Reply: 4L60E year question
