What is the stock convertor stall?
Old 04-26-2004, 06:25 PM
LS1FIRE's Avatar
Default What is the stock convertor stall?
What is the stall # for the stock vertor?
Old 04-26-2004, 06:33 PM
ActionJack's Avatar
I would guess 2300 stall.
Old 04-26-2004, 09:17 PM
Kenafin_02TA's Avatar
I think I heard that it's around 1800....
Old 04-26-2004, 10:10 PM
heyitsTaJay's Avatar
1600 with a 1.6str
J
Old 04-27-2004, 08:47 AM
Colonel's Avatar
The stock converter in my '02 checked out at 1900. Seems like I remember my '00 checking out at ~1850. (This was done by using the "2nd gear start" feature available '00+.)
Yank's site lists the stock converter at 1600 with a 1.8 STR.
Old 04-27-2004, 09:06 AM
lnuxhakr's Avatar
What are you referring to here?
Old 04-27-2004, 09:14 AM
Colonel's Avatar
If you have a '00+ F-body you can literally start off in second gear by placing the tranny selector in "2". Even at WOT it will not downshift to 1st. Try it.
This can be used to check the true stall speed of a converter. All you gotta do is hold the brake to the floor, hold the throttle to the floor, and monitor the RPMs (best done with Autotap.) BE CAREFUL doing this! You don't want to run over anything/anybody!
Old 04-27-2004, 09:23 AM
lnuxhakr's Avatar
if i were to start in this manner...from a stop...at what rpm will i need to shift to 3rd... or D
Old 04-27-2004, 10:07 AM
Fierce-LS1's Avatar
Originally Posted by heyitsTaJay
1600 with a 1.6str
J
Hey man,
How's it going ? How do you like the verter ?
