Turbo action cheetah shifter
Old 06-14-2013, 11:28 PM
ra79428's Avatar
Default Turbo action cheetah shifter
Can anyone post pics of one installed or some kind of write up, I attempted to install it tonight and it seems like the abs sensor would get in the way, I have an 00' ss with a th400. Thanks in advance!
Old 06-14-2013, 11:30 PM
ra79428's Avatar
I meant air bag sensor under the armrest.
Old 06-15-2013, 11:19 AM
ra79428's Avatar
bump...
Old 06-15-2013, 11:20 AM
ra79428's Avatar
I have tried searching for this but it seems the threads are all old and i cant find many pictures of them installed without the console on, just need help figuring out how to mount it so the console will work with it.
Old 06-15-2013, 12:29 PM
Back in the staging lane
Beeler422's Avatar
I'd send you some pics of mine but I won't be home for 2 more weeks.
Old 06-15-2013, 02:22 PM
ra79428's Avatar
Thanks man, I would appreciate that, anyone else want to chime in?
Old 06-17-2013, 08:49 AM
Beeler422's Avatar
If I remember right, I think I made a steel bracket that comes off the back of the shifter and mounted it to the tunnel behind the shifter. So the shifter body cantilevers above the sensor. But I'd have to look to be sure.
Old 06-17-2013, 12:59 PM
ra79428's Avatar
did you trim the consoloe at all? it looks like the plastic piece underneath would get in the way from the cable bracket part of the shifter.
Old 06-17-2013, 11:44 PM
Beeler422's Avatar
I don't remember having to trim the console except where the shifter body goes thru. But it has been years since I installed it so I could be mistaken.
Old 06-18-2013, 12:15 AM
ra79428's Avatar
I wish you were home already so you can take some pics, lol
Old 06-20-2013, 07:24 PM
ra79428's Avatar
Anyone else? i just dont want to hack anything up that i dont need to.
Old 06-23-2013, 01:36 PM
boss79z's Avatar
I am 2 weeks away from putting this shifter in my car also. T56 to th400. I would love to see some pics also
Old 06-23-2013, 09:09 PM
ra79428's Avatar
I am also still waiting for install pics under the console,every picture I search for has the console covering it up!
Old 06-23-2013, 09:10 PM
ra79428's Avatar
Can you remove that long bracket? I am thinking that would be the only way to make it fit.
Old 06-23-2013, 10:00 PM
Beeler422's Avatar
What long bracket? the one on the bottom of the shifter? If so, I left it right where it was. I can get you pics on thursday.
Old 06-23-2013, 10:13 PM
ra79428's Avatar
Yes, the bracket on the bottom of the shifter that holds the cable, I can't seem to figure out how to mount this shifter for a clean install.
Old 06-23-2013, 10:14 PM
ra79428's Avatar
So you didn't modify the shifter at all right?
Old 06-24-2013, 08:02 AM
Beeler422's Avatar
No, I didn't modify the shifter.
Old 06-25-2013, 08:25 AM
ra79428's Avatar
Ok, thanks, I hope the pictures you give might help. Thank you
Old 06-27-2013, 08:52 PM
Beeler422's Avatar
OK here you go. I did cut a piece out of the bottom of the console.
Quick Reply: Turbo action cheetah shifter
