4l80e questions, mount, cooler lines
I just fit my late core 80e into my fox. Now I need a mount, looking to get a poly mount. I need to make a summit racing order does anyone know what mount I should get from summit? I searched 4l80e transmission mount on their website and it didn't show any mounts in the results. I'm sure they have them I'm just a dumbass. Hoping you can help. Next I need to run my trans cooler lines. My question is can you run or I should say is it ok to run 90deg fitting off the transmission. I plan on getting the -6an fittings to put in the transmission to replace the factory ones. However it is sort of tight fitting. That's why I'd like to run the 90s.
