Aeroforce Interceptor trans temp observed
Just thought I would share this, I'll update it as I monitor it more frequently.
I plugged my Aeroforce Interceptor in today leaving work and paid attention to the temps. To be as explicit as possible, I started the car, left work and went to the bank (3 miles away) without monitoring. Leaving the bank I have roughly a 35 mile drive home, mostly highway but red lights around the bank and a couple closer to my house. While on the highway I went between 0-45% throttle.
Weather conditions were ~95* F temperature with a heat index between 98-100*, sun all the way home, no clouds or shade.
My car is an auto with stock 2.73 gears, a 3500 FTI torque converter (2.35 STR) and a Hayden 679 transmission cooler mounted on the condenser. The converter locks at 46 mph.
Upon starting the car leaving the bank the transmission temperature read 140*. I ran into some minor traffic and the aforementioned red lights prior to the highway. Trans temp got up to 183* at one point. As I got closer to the highway that dropped consistently. It quickly dipped below 180*. Once on the highway I expected it to level out to about 170* as it made it's way down, but I was rewarded by it dipping below 170*. By the end of the main stretch of highway home it was at 163*. After getting onto my second to last road it went up to 165* but then dropped down to 161*. I arrived home at 161* and I'm sure with a little more highway driving it would have been able to dip under 160*. Not bad for a 95+* day I'd say.
Hayden Automotive 679 Rapid-Cool Plate and Fin Transmission Cooler
-Size is 3/4 inch x 11 inch x 11-5/8 inch (for class "A" motor homes, large travel trailers, 5th wheel trailers)
-GVWR up to 30,000 pounds, towing up to 10,000 pounds
-Patented internal turbulation increases heat transfer with minimal pressure drop
-Pre-drilled mounting brackets for easy installation
Very nice
Mine got up to 183 driving 45miles to work today. Mostly highway and about 5 wot runs.
Air temp was about 85. Also done with Aeroforce guage.
I don't think my trans cooler is near that big though. It's a BM but not sure on the size. Maybe 24,000.
Note: I have the stock cooler bypassed
