4l60e output shaft.... How much play is ok?
Im trying to diagnose a lock up issue on my car.... I just removed the driveshaft and found that the trans output shaft has about 1/4 in play in each direction.... up/down, left/right. So total from up to down is probably over 1/4 inch...
Car goes in reverse ok..... I can creep real slow in forward.... but give it some gas it locks up for a moment.....?????
Moderator
You started another thread on the same topic:
https://ls1tech.com/forums/automatic...l#post17556532
So lets close this one and try to help you at the newer thread.
