Damage to 4l60e after blowing rear axle?
I blew up my 10 bolt rear end and then replaced it with a Moser ford 9. I drove the car a couple times and it was fine. Now, all of a sudden, when i take off, right before the 1-2 shift, something is locking up, pulling the car down and locking the rear tires.
I can idle creep the car around all day... I can also drive normally in reverse with no problems..... The new rear end spins correctly with the driveshaft removed...... Not the parking brake either becase I removed the shoes and still doing it.
Im stumpped to whats going on here.... The output shaft seems to have a good amount of play to it.... I really dont see any cracks in the tailshaft housing.... I need some help here!!!
Moderator
There is a another similar and current thread:
https://ls1tech.com/forums/automatic...-2nd-gear.html
I also saw your thread about the 1/4 of play in the output shaft. I don't have the experience to know if that is too much, but IIRC, Frank at Performabuilt replied to a similar question last year that even a bit more play is not unusual. Perhaps one of the builders can confirm or correct here.
Moderator
Perhaps the pro builder can confirm or correct me.
Moderator
Doubt any water has went though this trans.... Anybody else got any ideas? I think its strange it drove find a couple times since the new rear axle... then all of a sudden doing this???
Moderator
I don't think vwdave was implying you had water in your trans. He was saying that if the low/reverse clutch binds (or stays engaged) that the entire trans can bind up when it shifts into 2nd. In short, it could be a problem with the low/reverse clutch or the rear planetary.
However, I don't know this for a fact and wish a builder could confirm or refute this.
Anytime the rear blows up more times then not the trans gets damaged as well.I think the problem is your low sprag and race are broken and the center support could be cracked as well. The shock of the rear blowing goes through the driveshaft into the trans and sometimes it does not show up right away. I've seen this plenty of times.Did the rear break launching or under normal driving?
Happend launching in manual 1st about 5-10 mph.... Its in the trans for sure. Sucks after dumping $2300 into the car for the new ford 9 in rear axle. Also having alot of the car already apart too, to fix that.
Thanks for the replys
The following users liked this post:
Charlie Lucchesse (04-11-2020)
Moderator
