th400 and tci flexplate guys...
Im putting a 400 behine an 04/05 lq4 and i spoke with tci and the told me that flexplate 399753 will bolt it right up.can anyone confirm this? Im trying to figute if i need to get the crank spacer and bolts as i dont have the trans yet trying to get everything i need.any help. Thanks
The TCI 399753 has the LS and small GM bolt pattern. And most performance converters will have both the large and small GM bolt pattern. The TCI should come with a pilot extension as well, so if your converter has the shorter style pilot it will extend it to fit the LS crank. If you get a converter with the longer pilot just do not use the extender. Hopefully all that made sense...
Chris
Chris
ok so i have trans bolted to motor but with convertor locked in trans i have about 2 washer thickness between flexplate and convertor.is that still to much space or can i just put a washer or 2 between the two of them before bolting it all up?
