Can anyone tell the difference?
Yes, very tough to tell from the pic. An LS pilot needs to extend about .500-.550 from the pad of the converter to properly engage in the crank. You should be able to measure that fairly easy. FYI the typical SBC will only extend .200-.250 from the converter pad. And if you can get a measurement from center of one bolt hole to the next, we should be able to calculate the bolt circle from there.
Chris
Chris
Moderator
Just reading about this in the January 2014 issue of Super Chevy Magazine, page 48.
They mention GM spacer # 12563543:
http://www.jegs.com/i/GM-Performance...63532/10002/-1
And longer crank bolts #11569956, quantity 6.
http://www.jegs.com/i/Chevrolet-Perf...69956/10002/-1
You can run the crank spacer mrvedit suggested, but you will run it on the trans side of the flexplate. The spacer is designed to run with a flat flexplate on the 4L80 setup so you get the proper starter her engagement. But that has the 6 lug 11.5" bolt circle, so a no go for you. But there is a trick where you run the dished flexplate mounted to the crank and then bolt the spacer on the transmission side using it as a crank extender. And you will need to make sure the dished flexplate is a dual bolt pattern for your small GM bolt circle. Hope that made sense.
Chris
Chris
