4L80E Jakes/Lingenfelter
Have a buddy with a turbo F Body and we just got a Jake's D3 transbrake installed. Before the transbrake we would try to build minimum boost off the footbrake with the lingenfelter two step. Was lucky to make 1-2lbs of boost leaving. So far since the install it's been causing problems.
Transbrake was installed by a local transmission guy who has always done excellent work for us. Anyway, the car is throwing a P1810 code and it acts like the car I under more of a load when in gear and it wants to surge and die while in gear. The other thing is that the transbrake keeps blowing a 30 amp fuse.
Today I wired it to a relay and installed a TVS diode that Lingenfelter sells, however same problem. I should add this. It seems to only pop the fuse right before the two step activates at the set RPM, so far is hasn't popped the fuse using the transbrake to back up.
Any insight would be greatly appreciated.
