4l80 yoke question
Old 09-26-2013, 11:16 AM
dickwiley's Avatar
Default 4l80 yoke question
What yoke do I need for my 4l80. Its goes from the splines to a gap then o-ring. The bolt on yoke thats on it is short. The trans is a 98. Its goin in my 94 c1500 behind a 5.3. I don't have away of cutting the yoke if its to long.
Old 09-26-2013, 02:42 PM
dickwiley's Avatar
Default picture of the shaft
https://ls1tech.com/forums/attachmen...1&d=1380224512
Old 09-27-2013, 03:33 AM
got-a-ls1's Avatar
the strange u1664 should work. i have one in my car. the end of the yoke is counterbored, something i didnt know or need as my shaft is fully splined. i bought a mark williams yoke but the splines wouldnt fit so i bought that one.
Old 09-27-2013, 08:57 AM
dickwiley's Avatar
Yea this is goin in my truck so I figure I should probably use a bolt on one.
Old 09-27-2013, 10:33 PM
dickwiley's Avatar
Ok so I found that 4l60 thats I'm my truck now uses a slip yoke so I figure I otta get the same thing.
Old 09-28-2013, 01:24 AM
mesterious's Avatar
https://ls1tech.com/forums/automatic...1650-yoke.html
Old 09-28-2013, 07:19 AM
Gonoma's Avatar
I had my output shaft machined down to fit a regular style yoke when I had it torn down for the rebuild. If you can't do that then you will have to get the counterbored one that everyone is talking about. The bolt on yoke is used in trucks with a different type of drive shaft
Old 09-28-2013, 11:34 PM
dickwiley's Avatar
ok so everyone has different suggestions lol. since i need movement in my drive shaft the only place i can get that with my stock drive shaft is with the yoke. my 4l60 has a slip on yoke. so i kinda figure i gotta run a slip on since im using the stock drive shaft. the yoke thats on the 4l80 is a bolt on and its short. I believe a short slip yoke would be to short would it not? so should i get a long one and hope it works or get a short one and hope its long enough and wont fall out.
Old 09-29-2013, 09:29 AM
Gonoma's Avatar
It doesn't matter if you get a long or short slip yoke with a bolt on style output shaft. The output shaft gets bigger past the splines so it won't let you slide it any farther
Quick Reply: 4l80 yoke question
