shutter at 45mph-50 mph/3rd to 4th shift.
Lately my 99' T/A has a had real quick shorter shutter from 45-50 mph at the same time its going from 3-4.Is that a pretty common issue with the 460Le I know on a lot of the gm trannys. theres TSB pertaining to this with switching the steel plates and the fiber plates in the forward clutch I know on trans axles in forward clutch I seen on all data,but haven't seen that for a 460le or could it be I have a ujoint binding a bit which doesn't make sense but I have seen stranger any help would be greatly appreiciated.
Thanks guys.
Thanks guys.
