4l60 problem with nitrous only
Old 10-12-2013, 01:49 AM
rhodes37's Avatar
Default 4l60 problem with nitrous only
I got a rpm lv. 5 4l60e. I just ran it at the track and it will shift good on just motor no problems at all. But when I add a 100 shot to it it will not shift from 1 to 2 just bangs off the limiter till i let off the gas then will shift . I have a window switch set to shut off 200 rpms before the shift. Car shifts at 6400 and has been tuned for nitrous made 524whp on 100 shot. Any ideas?
Old 10-12-2013, 06:13 PM
Moderator
mrvedit's Avatar
The band is not engaging tight enough.
Who's "level 5" is it?
Sorry, but I don't think a Level-5 from e.g. FLT or RPM would have this problem unless it had a lot of miles/abuse on it. If it is from them, contact them for a refresh.
Otherwise, the trans needs the following parts which can be installed without removing it:
1. A .490/.500 boost valve - such as the Sonnax 4L60-LB1.
2. The largest 2nd gear servo - such as the Sonnax Super-hold #77911-03K
(This is difficult to install with trans in an F-body, but not impossible.)
3. The 1-2 accumulator should be checked to ensure the piston is not cracked.
This is a good time to install an aluminum piston or a Sonnax Pinless piston.
It is also important that the tune be set for max line pressure during WOT shifts.
Of course, if the band is worn and/or low quality, the trans will need to be removed and rebuilt.
Old 10-17-2013, 06:39 AM
rhodes37's Avatar
Its a rpm lv. 5 milage unknown came with car when i bought it. Car is tuned for the 100 shot ran fine on the dyno. It will shift manually no problems. Going to pull the pan in a week and report back
Old 10-17-2013, 08:02 AM
nikon1999's Avatar
My car on nitrous the shift points flair from the converter loosening up. I drop my rpm a couple 100 and it works awesome
Old 10-28-2013, 06:45 PM
rhodes37's Avatar
Dropped the pan found a bunch of cluch dust and several small metal flakes any ideas on what it could be. Either way im swapping to a th400.
Quick Reply: 4l60 problem with nitrous only
