Installing heads, cam, 1-7/8 lts how long will my stock 60e with fti 4k stall last?
Old 10-18-2013, 04:38 PM
j88l98irocz's Avatar
Default Installing heads, cam, 1-7/8 lts how long will my stock 60e with fti 4k stall last?
Just like the title says guys the Trans works flawlessly as of right now with the fti 4k stall thoughts?
Old 10-23-2013, 02:33 AM
tnmotown's Avatar
Only one way to find out lol.
I'm sure you can get some use out of it during normal driving. But I wouldn't expect more then a few dozen hard passes before some symptoms start to show.
My brother had a cam and 4k stall and made a lot of passes through the stock one, only until a few months into it, the stocker finally gave. But you could be lucky with yours.
Old 10-23-2013, 04:21 AM
nj02z's Avatar
I have been on my stock trans with 4k stall and running in the 11's for the last year.I take the car to the track as much as possible and usually enter two classes. I realize I might be on borrowed time but I cannot see replacing it until it starts acting up,it has been fine so far. I might add my car has low miles on it.33k
Old 10-23-2013, 09:58 AM
This makes me feel better.
Old 10-28-2013, 11:23 AM
01dropTOP's Avatar
Honestly, it really depends on your driving habits (always in it, high RPM shifts, granny driving, etc)
Do you have a trans cooler yet? if not GET ONE ASAP. Also get a temp guage to monitor the temps.
My tranny lost 3-4 gears at about 150k miles. So I got it rebuilt locally about 2 years ago and now I have about 173k miles, guess what, no more 3-4 gears. Im just going to do it right this time and get a built tranny with a huge cooler in it AND get a temp gauge.
Ask anyone, the biggest cause of transmission failure is heat. With the converter, we just heat it up that much faster.
Good luck with it and let us know how it works out!
Old 10-28-2013, 11:31 AM
Ill run it hard occasionally but not every time I drive it. Yes I have a huge Trans cooler.
Old 10-28-2013, 11:37 AM
wildcamaro's Avatar
My trans lasted about 15k miles after my heads and cam swap with approx 30 track passes with stock converter, to be fair my rearend blew up at the same time so that could of had something to do with it lol
Old 10-29-2013, 06:50 AM
Did some tuning last night seems to be holding strong so far...
Old 11-03-2013, 04:17 PM
metlic53's Avatar
Probably not very long but you might get lucky. Some seem to take abuse better than others.
Old 11-03-2013, 05:26 PM
Still holding strong... I made probably 10 wot pulls and so signs of malfunction so far I'm sure this cold air helps keeping the Trans temps in check and the weight reduction I've done doesn't hurt either.
Quick Reply: Installing heads, cam, 1-7/8 lts how long will my stock 60e with fti 4k stall last?
