th350 wont go
th350 wont go
I cant get my trans to slide on the guide pins, converter is installed properly, wen I had the guide pins out they were a tite fit but did go in, shud I just try fighting it on there or what, and isnt it a bad idea to use bolts to pull the trans in? Please help im gonna try to get it in tomorrow
LS1Tech Sponsor
__________________
LS1Tech Sponsor
Do not try and install the trans this way but to make sure converter will work with engine try putting converter alone to flex plat and see it it will go up flush. If so then try the trans alone in the same way This will help determine the issue.
Frank
Frank
__________________
