4l60e dtc 2830
Moderator
I see that no one has replied.
I cannot find any info on a code 2830 related to these cars. Are you sure you have the code # correct. Never heard of a "circuit K" either. There are no sensors in the 4L60E other than fluid temperature. All codes are related to an open or shorted solenoid, or the PCM detecting slippage.
Why not start with a description of what the problem and symptoms are.
