Can a ls1 flywheel be used on a 4l80 with aftermarket converter?
I beleave after a ton of searching this combo I have will work
2000 camaro ls1
97 4l80e
SFI direct factory replacement flywheel (4l60)
Yank converter (4l80e) and if I specified 3 bolt ls1 mounting in the order
Will this bolt up properly?
I assume that the 6.0 spacer is no longer required because the converter will have a longer ls1 snout...is this correct?
2000 camaro ls1
97 4l80e
