Tracking down this clunk!!
Iv done searches for this for awhile never see anybody with the problem resolved so I thought id ask. When driving an coming to a complete stop I get what feels like a kick from the rear of the car when all the momentum shifts to the front. I damage my diff tracking this noise down.(Don't ask) anyway iv got a new rear new brakes all fluids changed an to my knowledge I checked all suspension parts an everything seem tight. An whats wierd is if I throw it in netrual before coming to a stop it's smooth take it out put in drive its clunk when it downshifts to first if anybody has had this problem before I would like to hear some opinions plz car is a4 T/A
I have the same problem you do. It's really annoying. Mine feels like it comes from the middle of the car, and my drive shaft is relatively new (installed in may). I'm thinking it might be a worn out TQ arm bushing or trans mount. Anyway, good luck OP let me know if you get it fixed.
I confirmed today that is the slip yoke causing the thump. I was told that greasing the splines is only. Temp fix and can also be bad because of Greece getting in the transfer case. So I rather just replace the slip yoke problem is I'm doing searches and can't find where to buy. Any ideas.
Moderator
My local drive shaft shop had 1330 yokes in stock and made me a custom drive shaft. There are lots of drive shaft shop around for servicing big trucks.
1350 Yokes are even better. Just Google "1350 Yoke"; JEGS and Summit sell them.
My cuzzin and I have the exsact same car accept his is black I took my entire driveshaft off an put his in ran it for an hour or so not 1 clunk in reverse nor at a stop am go but he wouldn't let me keep it even tho he doesn't drive his anymore installed mine back clunking away... An the dealership said 110 just to remove an grease it i modest well just buy another 1
http://item.mobileweb.ebay.com/viewitem?itemId=370957856710 is this the 1 u are referring to??
Moderator
That is the rear yoke, not the slip yoke. Search for "slip yoke 4l60e" on ebay; although I rarely find the lowest price on ebay. Same price on Amazon:
I estimate your local driveshaft shop will charge you $120 plus the yoke to weld in the new yoke and re-balance the drive shaft. They probably stock or can quickly get a 700R4/4L60E yoke in either 1330 or 1350 steel.
Ok here is the scoop remove drive shaft then remove extension housing there should be a little cup with a o - ring inside it replace the o-ring and put the proper grease on the splines and in the cup . If the cup is missing get one a lot of builders toss them . While you are there replace the extension housing bushing and seal . GM special grease, P/N 19257121
