Fittings for 70274 cooler help!
Hey guys im new to this and i need a little help finding some fitting for my trans cooler
http://www.ws6project.com/user_stor/catalog/93-02-b-m-transmission-supercooler-29-200-btu-/
This is what i got ^^^
Thankz.
Thankz.
Should be 1/2 NPT. You can get one that turns to a nipple for hose (use trans cooler hose). This one is brass and can be found at home depot or any plumbing store. You can also order a 1/2NPT to AN adapter and run braided line. I've run mine both ways.
Is there a size for that brass one?
Home depot's website is being gay but this is what you need and they do carry it:
http://www.ebay.com/itm/STAINLESS-STEEL-HOSE-BARB-1-2-hose-1-2-NPT-PIPE-/251405814626?pt=LH_DefaultDomain_0&hash=item3a88f44b62
https://ls1tech.com/forums/gen-5-cam...en-camaro.html
Fittings are listed here under transmission cooler parts
Depends on location. The stock cooler functions really well as a warmer for cold climates. Down here in the dirty south we need to ditch it asap.....but up north it can be beneficial to regulating the trans temps....Why you ask? Well because when its cold, and the factory warmer isn't there, the trans just wont heat up. It can literally stay 100 degrees behind a 200 degree engine.
