High-Flow 160F Transmission Thermostat
LS1Tech Sponsor
Improved Racing has released a low-temperature version of its high-flow oil thermostat for use with transmission and differential coolers.
The thermostat helps improve efficiency and prolong transmission life by minimizing warm up times and helping to maintain a minimum fluid temperature of 150-160°F.
The unit is made from anodized billet aluminum and is available with -6AN through -12AN fittings, with hose barb fittings coming soon. Prices start at just $159.
Our thermostats use a unique design that locates the valve assembly out of the primary fluid flow, which minimizes the pressure drop across the unit and improves flow.
For more information visit http://www.improvedracing.com/thermo...60f-p-423.html
P.S. By popular request from several race teams (including Corvette Racing - our thermostat is in the C7 Le Mans car), a high-temp (212F) oil thermostat for racing applications will be available in January 2014.
