99 Z28 M6 to TH350 Questions
I just bought a car that has a M6 to TH350 swap. The speedometer and Reverse lights don't work. Can someone please tell me what I need and how to get them working? Thanks
Here is a free way to make your speedo work:
https://ls1tech.com/forums/automatic...eedo-work.html
Not sure on the reverse lights for an m6 car.
if you would like your reverse lights to work, you will need to tap into the brown wire and the light green wire on the M6 harness (passenger side) underneath the car.
Speedometer: I used this method for over 6 years now,
Quote:
Originally Posted by SUX2BU
Posted this a long time ago but since the search doesn't go that far back anymore thought i would repost it.
splice your speed sensor into your front wheel sensor. if were an M6 put in 2.76 for your gear ratio, measure your front tires and put that in as your tire size.
You will lose your ABS.
Ok if you were an A4 you put in 1.175 for your gear ratio. and front tire size for "tire size".
Oh and if you want your speedo accurate please measure the circumferance of your front tire and divide it by pi (3.14) and that is your EXACT tire heigth.
