4L80 or 6L80 in 69' Skylark
Hi, I just picked up my 1st LS motor. 2006 LQ4 from a 3500 Savana Van. Anyone can direct me which tranny I should go with? 4L80 or 6L80 or any other suggestions? It's going into my 69' Skylark. I do know the 4L80 fits in the car like a glove but I do like the idea of 6 speed.
Your thoughts please..
Thanks Chris.. I'n not trying to kill my pockets.. I just happen to find a 35K mile 6L80 for 500.00 thats why.. but I think it will be a headache.
Moderator
There are likely a slew of problems using a 6l80E:
1. It probably will not fit without enlarging the tunnel.
2. You likely will need a $800 controller
3. IMO the gear ratios are not well suited to anything lighter than an SUV
4L80E are readily available in junk yards and are all basically the same, and with even a stock rebuild will easily handle 600+ HP. Several members here have pulled them out of mobile homes for well under $500.
Can any year 4L80E fit my 2006 LQ4. What is my year range?
Go with the 4L80E. Do your research and you will find that's it now possible to convert it to a 6 Speed with close ratio gearing and engine braking in all gears later on.
If you decide you like that idea, to save money later on choose TCM from company that offers the components, valve body, gear set, ect to do it.
http://www.powertraincontrolsolution...ed-Valve-Body/
