Re-stalled my Circle D converter. - RESULTS ARE IN!
Old 12-26-2013, 08:55 PM
Old School Heavy
speedtigger's Avatar
Default Re-stalled my Circle D converter. - RESULTS ARE IN!
So, after a few years with my Circle D 2B (2800-3000), I had it re-stalled to a 4C (3600-3800). I also had the transmission freshened up and upgraded to a Stage 2 while it was out. I drove it a little Christmas Eve and all day today.
The first thing I noticed is that it does not pull the engine down hardly at all when I put it in gear. The old converter would pull it down about 250 RPM. The new converter maybe 100 RPM.
At very light throttle, it behaves about the same. At moderate throttle the RPMs come up about 500 RPM more. At a moderate to strong part throttle the car pretty much sits at 3500 RPM as it goes through the gears now. At more aggressive part throttle the car feels quite different.
At full throttle the car is much stronger in 2nd gear. It actually feels like it pulls harder in 2nd than in first. It was the opposite with the 2B converter. The shift extension with the 2B were about 1800 RPM. Now they look to be about 800-1000 RPM. The car really stays in the powerband and it sounds ferocious. It jumps up on the cam fast and hard and stays there.
I am curious to see how it runs at the track now. I expect it to be quicker on the motor. I hope it does not lose any MPH and I hope it still runs as hard on the nitrous. Time will tell.
Old 12-26-2013, 09:11 PM
NHRAFORMULA00's Avatar
8-900 rpm extension is right where you want it. Don't worry about mph, the converter is converting it into exceleration. I'll bet your gonna be real happy after your next visit to the track
Old 12-26-2013, 09:42 PM
1BAD98LS1's Avatar
Should 60' a bit better, maybe keep the same MPH but faster ET... or... since it stays in the powerband longer you may get the best of both worlds. Should be nice
Old 12-27-2013, 07:52 AM
SSZ
SSZ's Avatar
Excited to see some results. I think i should get myself a late Christmas present and order one of these Circle Ds. I like what i am reading about them.
Old 12-27-2013, 09:30 AM
murphinator's Avatar
if it feels that much different/better on motor maybe she will have a 10.99 in it
Old 12-27-2013, 09:46 AM
Old School Heavy
That would be pretty awesome, but I would be surprised to see it make that much difference. Maybe in a some negative D/A with a tail wind.
Old 12-27-2013, 09:56 AM
Circle-D's Avatar
Sounds like the 4C is going to de very well.... Keep us updated.
Chris
Old 01-08-2014, 09:51 PM
Old School Heavy
Went to the local 1/8 mile track tonight. It is pretty much like racing on an unprepped street, so I never got a really clean pass. But, even lightly pedalling the car it still ran a new best on the motor. I am guessing when I get down to Bradenton Motorsports Park that the 60' times will be in the 1.5s on the motor and be about 2 full tenths quicker N/A. And I am really curious to see how it handle the nitrous.
Old 01-09-2014, 12:06 PM
nocooler's Avatar
Looks good man!
Old 01-11-2014, 10:19 PM
"All Motor 9 Second club member"
TXCAMSS's Avatar
Very nice run!! A better prepped track a little spray and she will be rolling on out.
Old 01-11-2014, 10:23 PM
senicalj4579's Avatar
I remember your thread a few years back and told you to go bigger. So what happened? LOL!
I will probably go 4k next time around myself.
Old 01-18-2014, 04:59 PM
Old School Heavy
Default The results are in!
The results are in! About two full tenths quicker on the motor and the MPH stayed the same. On the nitrous, it ran a near identical time, but my bottle pressure was lower than normal after the pass, so the jury is out on that one until some more testing.
The cool part is we have a pretty close to apples to apples comparison. The D/A and wind was near identical to my old fastest time with the old converter.
Here is my old best on the motor with the old Cirlce D 2B converter:
Here is the new best on the motor with the new Circle D 4C. As you can see, the car is incredibly consistent for the street cruiser with the new converter.
Here is my old best on nitrous with the old Circle D 2B converter:
Here is my new best on nitrous with the new Circle D 4C converter:
As you can see, the nitrous passes are virtually identical. However, I was struggling with bottle pressure today. So, I will need more testing on nitrous before I will draw any conclusions there.
Old 01-18-2014, 05:18 PM
AINT SKEERED's Avatar
Very nice. 10.99 coming soon on motor and 9.99 on spray
Old 02-18-2014, 04:01 PM
Old School Heavy
Chris
I wanted to update those interested in the converter's reaction to nitrous. I had mentioned that I did not want to give my final judgement on the converters ability to handle nitrous until I did some more testing.
Well, I went back out this weekend and was able to maintain consistent bottle pressure and the car went a 10.16 @ 132 on a 73n jet in much warmer weather than last trip. So, the issue last time was definitely bottle pressure. The converter is doing a fine job handling the nitrous.
In fact, I upped the nitrous jet to an 81n tune and it continues to respond to the tune of 10.04 @ 133. Not bad for a SBE full weight street car at #3780. Here is a motor pass and a nitrous pass with the new Circle D 4C converter:
On the motor:
On the nitrous:
Old 02-18-2014, 04:17 PM
Beave's Avatar
Awesome man! congrats on the strong runs.
Old 02-18-2014, 11:40 PM
TXCAMSS's Avatar
Very impressive man. Thanks for the update.
Nice car you have there also.
Old 02-19-2014, 08:27 AM
Circle-D's Avatar
Very nice, a little better DA and you will have your 9!!
Chris
Old 02-19-2014, 05:36 PM
Old School Heavy
Chris
Thanx Chris. The D/A will help me get my N/A 10 second pass for sure. I will have my 9 second pass with or without great D/A. I can see with my testing, that this converter can handle more jet. So I can just jet up if I have to for the 9 second pass.
Either way, props for nailing the converter. I told you I wanted a converter that could deliver a 10 second N/A pass and a 9 second nitrous pass. You have delivered. The reset is up to me.
Old 02-20-2014, 07:49 AM
01ssreda4's Avatar
That old girl is moving.
Quick Reply: Re-stalled my Circle D converter. - RESULTS ARE IN!
